replacement bracelet
innocenti
705
155
Broken noob yachtmaster bracelet has 600 78800 stamped on inside of SELs.
Is this the only 20mm that will fit / what I need to look for ?
Stuvetjee
Russian Spambot Sales Moderator
10,495
4,056
NL / Schweizer
Email the TD you got it from, he perhaps can supply you the bracelet.
innocenti
705
155
TD has advised that watch is out of stock and therefore they will be unable to source a bracelet.
Anyone got any suggestions ???
116622 Noob Grey a2824
https://puretime03.com/watch-brands...gray-dial-blue-hand-on-ss-bracelet-a2824.html
Solid End links have 6dd 78800 stamped inside
img_5575-jpg.64571
img_7262-jpg.64568
img_7263-jpg.64569
img_7264-jpg.64570
innocenti
705
155
Would any noob yachtmaster bracelet fit no matter what movement the watch has ??
innocenti
705
155
Any advice guys ? I'd love to get this back on a bracelet.
johnlogan
9,576
11,944
I told you this in a different thread - YES it will fit regardless of movement. Intime will hit you up.
QueTip
14,325
5,259
Isn't the bracelet attached to the movement through the springbars? :hehehe:
innocenti
705
155
Just want to be 100% sure as have already bought other noob bracelets and Angus told me it's not available as my watch out is of stock and assumed
he would have suggested it.
Will now look for any noob yachtmaster bracelet.
johnlogan
9,576
11,944
Indeed, removing the bracelet with force might harm the center wheel piston and spring barrel ( proceed with caution ) :hehehe:
innocenti
705
155
Forgive me for taking advice from Angus regarding a noob product.
Sometimes we all ask questions others may perceive to be stupid.
Only the other day someone asked about taking a fake watch to an ad for a service.
johnlogan
9,576
11,944
We are just messing with you bro. Reach out and order the new YM bracelet to make your piece complete yet again.
innocenti
705
155
:thumbsup::thumbsup:
Have asked Angus and if not will try ryan.
innocenti
705
155
Noob sub and noob GMT bracelets don't fit. Been told end links differ.
bubu77
186
EUROPE
A Noob Yachti bracelet schon be fit on all Noob 116622. It´s always the same Case. There are no v Editions of the Rolesium watches. Just the Movement or bezel is different.
Only Problem is BP bracelet on a Noob case or Noob bracelet on a BP case. Bp Lugs a little bit differnt than the Noobs lugs. You can get a 116622 Noob bracelet at every TD.
Try the standard Noob 116622 bracelet with fat springbars. Should be working
innocenti
705
155
Well from what you all say I can only conclude that the new noob gmt2 bracelet I bought M2M is not noob as just had another go and end link is wrong to sit at watch properly.
Noob yachtmaster left
Noob (sold as) GMT2 right
