Every single Rolex Case#, Crown# and Tube#
Bonesey
8,926
66
Case Tubes
Crowns
justlounging
2,725
100
Great stuff R!
Is this in the Wiki Pages as well? definitely a sticky..
Bonesey
8,926
66
Yup, in the vintage WIKI page at the moment but I will compile a sticky with a full list of references and guides etc.
Rudy40
9,373
This is very useful.
Thanks for sharing! Great work!
:cheers:
Bonesey
8,926
66
See the references for 16660, 16610 and 14060. The addition of the extra 1 in front only denotes a new version but the crown tube reference hasn't changed AFAIK.
Jake48
545
I believe the tube is the same size, but I can't say for sure. I know for a fact, however, that on the new bigger style cases the crown is definitely bigger so dropping the 1 on case # will result in the corresponding crown being too small.
Can you get the correct new numbers fro the crowns?
Bonesey
8,926
66
You are correct, the 116660 crown is now 8mm. The crown on the 116610 and the 114060 are exactly the same size as the new series. You won't find a spare 8mm gen crown unless you have a parts account with Rolex.
