Rolex Submariner Case Dimensions and Changes
Subjeff
7,104
57
Rolex Submariner Case Evolution
5508 and 5510 - case size 37mm
Notes: The lugs tend to be slightly thinner and have more of a downward curve compared to later models.
5512 "square crown guards" case size -39.5mm
Note: This was the first generation of rolex to have cg's and very few were made. The case and lugs seem to be thicker and have less of a donward curve vs the non cg model.
5512 (pointed crown guard) case size 39.5mm
Note: The case and lugs are noticeably thinner than the square cg model. Also, the edges are much sharper and not as beveled. I believe a lot of the shaping in the manufacturing process was done by hand and has lead to these inconsistencies.
5512, 5513, 5517 and 1680 - case size 39.5mm
Note: There also seems to be a lot of variance in the GC thickness, length and width within this series. These variances can be noticed on the same watch from the top CG to the bottom CG. Once again I belive the hand work during the manufacturing process has lead to these inconsistencies. (In my study of many pics it seems the bottom CG is usually thinner?) In the 1680 series is when the International Orginazation of Standardization made detail requirements on dive watches. This is when these variances seemed to stop.
16800 - case size 39mm
Note: The case and lug edges are much sharper than 1680. The case is also slightly thicker
14060 -case size 39.5mm
Note: The lugs are very similar to the 16800. Also, if you notice the CG's protude about 3/4 the length of the crown and are thinner than 16800.
16610 - case size 40mm
Note: The lugs visually look slightly fatter than 14060. This could be due to the case being slightly thicker.
Lug, Case and CG Evolution
From the bottom up
5510
5512 (square cg's)
5512 (pointed cg's)
5513
16610
Rudy40
9,373
Ooh yeah love looking at these pics! It pure sex baby!
Subjeff
7,104
57
I got some of these off RWG but thought it would be great if added here in this section. These pics are a few years old!
MBW/Polex 5512 comparison to gen
1680 MBW? comparison to gen
Euromariner/WM9 comparison to gen
Bonesey
8,926
66
Any info on the square crownguards or pointy crownguard models?
Subjeff
7,104
57
Now that I have most of it on one page I will continue to add and edit. Hmm I wonder who suggested it?:thinking:
Bonesey
8,926
66
Awesome. Going to be a great reference guide for those of us who re-shape crownguards a lot.
Subjeff
7,104
57
Still a work in progress. I would like to see people do comparisons of their reps and post them here as well. What are your thoughts?
Bonesey
8,926
66
It depends mate, there's such a massive variation on reps that trying to compile all that information may take a life time. If we have a comprehensive catalogue of genuine crownguard shots then people can make their own decisions based on what they see here. They should also be able to use it as a guide for re-shaping any crownguards on vintage pieces they may be working on.
QueTip
14,596
5,922
I just saw this the first time, great write up Jeff! Very informative
