AP 15400 link removal help...
Ohsoo01
hi, all after searching forum I see no posts that can help me, how do I remove the pin after I unscrew the flat end on the 15400?, how would I push the pin out?... from inside the bracelet or the other end?
Thank you.
WingNut
Brig Warden
4,025
1,302
Thank you.
After you unscrew it all the way grab the end with tweezers or small needle nose pliers and pull out or push out from the other end with a pin or such.
Ohsoo01
How would I fit a tweezer in between to pull out?, and if I push out I need a needle going in the hole to push it out right? Not the other way?
jeranimo
34
unscrew the link, then push the pin from the other side in. the pin wil pop out on the side where you just removed the screw and then you can just pull it out. struggled the same way. hope this helps
Ohsoo01
So push the pin from the side that is has not just been unscrew?
jeranimo
34
so first remove the screw on this side and then
push the pin on the oppositie side, so you push this pin inside the braclet
Verzonden vanaf mijn iPhone met Tapatalk
Ohsoo01
Thank you... I finally understand.... after pin is push through I put the pin back in via that little hole right?
jeranimo
34
You put the pin back true the screw hole and pus in back into place.
jeranimo
34
Havent found one. But just reverse the proces. Of getting the pin out
Ohsoo01
Thanks for your help, one last thing... the pin has to be pushed inside the bracelet hole right?
