- 24/5/18
- 28
- 3
- 0
Will try to stay completely factual, no emotions. Just received my second order with 3 watches. Two seem to be ok but one of the watches is Cartier Ballon Bleu Ladies 36mm and it came completely botched.
Timeline and details:
- received QC pics for Cartier. All looked good but the beat error (s/d) was little high so I asked for a slight adjustment which their “watch smith” did and Elena later sent just one pic showing the watch (from the side) on the testbed next to the monitor. Beat error was fixed somewhat so I okayed the watch.
- fast forward about 18 days and I open the package. What I see is really bad. The case is scratched quite deeply in the sides. Caseback as well. Worst part, all the screws are messed up, while A) one is obviously crooked by torque forcing it in, just half way in and stuck with its head mingled. B) Another screw is completely messed up and once I just touched it, the head fell off! The screw nest is obviously was mingled as well and has a trace of some residue like someone tried to mask it. Seeing grinding marks around it on the caseback. Sides of the case around these two screws are deeply scratched like the driver skewed to a side while being used. Not acceptable whatsoever.
- I just sent the detailed email with pictures to puretime asking for a resolution of the problem. Hopefully they will demonstrate their dedication to customer service they are being praised for.
Next problem is their CC processors. Two transactions (June and July) and two credit cards replaced as a result. Reason, card hacking. Both times in about a week or two after transaction with puretime, I received the fraudulent charges alerts (Apple store in both cases). Both times requested my CC company to stop the transaction and issue a new card. Main implication here? I get the complications with payment aspect but if you don’t switch to at least a semi-decent credit card processors you are at risk of loosing quite a few customers who will be put off by the prospect of their card being hacked. You definitely should look into this matter.
Bottom line:
1. Waiting for a resolution for Cartier from puretime.
2. Hope that puretime will look into the CC processing issue more scrupulously.
Will try to upload the pictures of botched “in-house watch smithing”.
Thanks for reading this long post and hope that somebody will find it useful.
Bottom line:
