How waterproofed are Omega reps? Aqua Terra 150M VSF 8500 or A8900.
Pixelman
8/11/19
64
17
Hey guys. Anyone ever had to take their Rep Aqua terras swimming or in the rain? Do VSF come with some water proofing at all or is best to treat it as you would like a non water resistant smartphone.
indierock Jim
Horology Curious
3/7/19
I wouldn't take any rep near the water. I've read about taking it to a watchmaker for waterproofing but to me it makes more sense to take a gen that's made for the water in the first place.
chocolito
1,661
861
I have had a rep pass a 10bar WR test and have had others which would leak like a sieve , so it's a lottery . When you get the watch have it pressure tested before you take it anywhere near water . You may find it is good to go ,you may not . There are a number of things a good watch smith can do to increase water resistance on a watch so you can use in water .Such grease / or replace gaskets , press crystal etc etc
TESLA760
Time is Money $$
23,037
15,967
Socal Wine Country
I've swam with many reps throughout the years. No watch is waterproof. Many are water resistant for quite decent depths. You have to use common sense. I'd never swim with my gen chronos. The same applies in the rep world.
kissmark69
30/9/19
81
11
i cleaned mine many times with running water and its perfectly fine...
LPGT56
27/10/19
36
14
The manufacturer (VSF) claims at least 30 metres (3 Bar) from the factory. I will have mine (James Bond AT V3) pressure-tested while Strodda has it in for service (clean, lube, and calibrate) and post the results when available.
Nanook65
1,973
950
All reps might or might not be waterproof. Rep makers lie, ie they say watches are 1:1 etc when obviously they are not. So no matter what they say, it is better to be safe than sorry and have your watch tested before you go swimming with it. Once you have had it tested, I wouldn't hesitate to swim with a rep.
