MKF Spectre
BIONONE
Put Some Respect On My Name
28/4/17
3,566
2,728
not worth buying IMO as the new 8500 mvmt was just released this week...And probably for the same price like the MKF
The Rod
2,058
829
I thought this was actually the VSF with clone movement, as the balance wheel is black, while in the old 8215 with deco plates the balance wheel was the standard gold colour...but now that I look at the barrels they also seem different
Reactions: vcappp
BIONONE
28/4/17
3,566
2,728
the balance bridge is also different - not even close when compared to the gen or the new clone 8500
Reactions: vcappp
fabbe79
1,170
173
Nope 328 Vs 378 USD for the bracelet + nato version. The vsf movement seems a lot more expensive. A clone of 2824-2 is not a bad choice unless vsf clone is really reliable. And an Hi beat non indirect second version of spectre was something all the forum was asking for and now we have 2 maker to chose from
nine
177
46
Mks@12, wheel to small, to middle, VSF@6.
days setting, hands setting different,
Dial case ....
Reactions: phdsjain
Linear
241
41
One other problem:
JEWETS?!??!
Reactions: vcappp
ward1991
Luminor-Based
2,567
1,354
So looking like VSF as of now is the better option, anyone see when theyll officially be out?
These photos make it look great. The insert looks correct. I wonder if it was made like gen, pressed it or however they do it.
Sent from my SM-G950U using Tapatalk
The Rod
2,058
829
I asked Ryan, he said VSF stock arrives after mid july
imranbecks
2,157
3,265
The Neutral Zone
The photos of the watch at Chazingtime looks to be the actual rep. It looks good. The dial looks very gen. The nato strap looks brilliant and even the bracelet it comes with looks to be all brushed. Very tempted but I already have the V1 from V6F that still works fine and I don't think I need two Spectre SM300. Movement reliability is a question mark though.
I probably would get the non Spectre Seamaster 300 though if they would do it as a super rep. It probably isn't too far behind.
LaPavel
518
215
mkf version look better than vsf-v6f
vsf has really bad looking bracelet - same as on old v6f
mkf bracelet look like as a gen bracelet with all tags.
vsf clasp use same clasp as v6f with tm under gun.
​​​​​​​on mkf and gen isnt tm on clasp. sels are better on mkf
vsf bezel ring look smaller than gen, mkf has correct size.
vsf has more gen movement, but less stable than aeta mkf.
Reactions: phdsjain
-prick
208
41
we really cannot judge from just the few td photos
a good side to side comparison would be amazing
vsf looks really good till now though
