Omega PO 43.5 from kw
ShiroTenshi
6,811
259
Sent using Tapatalk
Tickleshoes
933
304
45th Parallel
Miyota or 28XX? If it's ETA based, it's nice to see the decorations improved. Now if they could just make the balance wheel black!
ShiroTenshi
6,811
259
Miyota 8215, kW/v6 nv like to use ETA clones. I rather the factory leave the balance wheel alone really, it's a part that can be damaged easily.
Sent using Tapatalk
nauticatom
407
109
It's a shame - those miyota style movements are terrible and you can't swap them out for a full blown ETA
Chel
262
Gen's got glossy dial. This looks like previous version of planet ocean with new orange numerals.
ShiroTenshi
6,811
259
While myself also prefer the eta clone movement for the higher beat, the miyota is a very reliable workhorse movement. Many factories have turn to the miyota due to the very low faulty rate.
nauticatom
407
109
While myself also prefer the eta clone movement for the higher beat, the miyota is also a very reliable workhorse movement. Many factories have turn to the miyota due to the very low faulty rate.
Haven't you seen all the stuttering issues with the miyota style movements?
ShiroTenshi
6,811
259
The stuttering is not all that common, and is not considered faulty also, its not affecting the time keeping.
Either way, just swap it out if you got one with the issue, the cost of a 8215 is only half of an ETA clone.
nauticatom
407
109
Fair enough - well said. My only other issue is the noisy rotor with them. You can hear a miyotas rotor coming down the street. :)
ShiroTenshi
6,811
259
Well.. I would love a glossy dial but thats the best available for now. Im sure kw/v6 is a more experience maker for omega PO reps than JHF which is the only other maker doing these new POs.
ShiroTenshi
6,811
259
That applies to the miyota 9015, and sadly is their weak point. However my 8215 seems quiet enough compared to an ETA clone (i just went to shake one of my PO with 8215 to confirm).
Tickleshoes
933
304
45th Parallel
Agreed. A drop or two of oil seems to quiet them and they're good out of the box. Would prefer an ETA myself but nice work by the factory!
amptor
871
I'm getting 12 hour power reserve from my miyota, kinda disappointing to set the time every day. Plus noticable stuttering but not real bad. I have had much worse 21j movements. ETA clone is suppose to get about 40 hours but from my experience it is less. Still better than 12 though.
Btw, regardless, beautiful watch and movement.
ShiroTenshi
6,811
259
Your miyota is spoilt. Time to put in a new one!
Sent using Tapatalk
GADGET213
1,431
226
I've seen this on CT and got really excited about it, now just need to find someone that can glossy dial mod and i'm in.
frediiii
430
77
They don't even bother makimg new SELs...
Gesendet von meinem LG-H850 mit Tapatalk
