- 5/4/20
- 391
- 118
- 43
Hello everyone, me again! I'm on the last leg of my DSSD build. I've just received a new bezel insert and its to thick. Its proud of the edge of the bezel ring and almost flush with the crystal.
I've tried using sand paper on a flat surface but as the ceramic is harder than the sand, tried wet n dry as well with no luck, I'm getting nowhere fast!
So what are you lads using?
Sent from my SM-T515 using Tapatalk
