Spring for Chs wheel
merlix
1,262
36
Hello
Anyone can help me to find that chs whell that is mounted ia an A2836.
Have the spring inside broke.
Thank you
Accepted also some idea to fix it.
Specter1000
1,256
615
Cincy area
That is the asian modification part added to the 2836's to make the GMT function. Other than buying a new Hangzhou movement, I don't think you can source them. There might be people here that have spare parts though....worth a shot.
merlix
1,262
36
Thank you
Hinclimincli
2,606
1,883
Thank you
Hey merlix , did you manage to find a replacement? That's the achilles' heel of the CHS movements indeed, although some people say that after some proper cleaning and lubrication they might last longer.
Did you do anything specific that broke it, or were you following the usual instructions? (never change the hour when the GMT hand is between 10 and 2, never move the hour hand backwards, etc...).
Mr.Marbella
1,493
599
I‘ve had the exact same issue on my watch unfortunately...Sitting @ domis since 1 month.
He managed to source a new spring for me but it broke again the same day.
Luckily a member here on Rwi sent his CHS gmt along with a Gen movement and several other Gen parts to my watchmaker, so now his old movement is landing in my watch.
Movement is a time bomb to be honest..hope they actually clone the 3186 soon.
Reactions: Hinclimincli
Hinclimincli
2,606
1,883
Thanks mate. In your case, did you follow all the recommendations? I'm just trying to find out if these recommendations work or it's still a hit or miss...
merlix
1,262
36
Hello
I fixed the spring with a part of an syringe needle.
It seems that work but I don’t know how long.
37,290
78,930
Hello
That's pretty ingenious bro. Did you use some epoxy on it? Should be stronger than new!
Reactions: Captainunderpants
merlix
1,262
36
Yes, a bit of epoxy need to use
Hinclimincli
2,606
1,883
Hello
OMG, I can't stress how amazing I find your solution. And not, it's not irony, I absolutely love it, lol. You might have solved one of the biggest issues in today's rep game!
Mr.Marbella
1,493
599
Not at all !
I was wearing it as my daily beater until one day the hour hand decided to give up.
Hinclimincli
2,606
1,883
Happy to help the forum members.
So, just to follow up with this, how is the spring holding up so far? Is it still working strong?
