- 31/8/21
- 47
- 2
- 8
Hello,
Just couple easy ones, any help would be greaty appreciated!
1.Is there an easy way to remove bezel insert from HR 5517 case? I would like just to replace the insert without prying open that complete bezel setup.
2.Bezel in trusty vintage piece seems to be loose, is it ok to just bend that ring under the bezel to make bezel rotation stiffer? I read that that ring should not be bent ?
