Announcement
Collapse
Please Consider Supporting RWI Today!
We depend on Supporter & Patron subscriptions to pay the bills. Please consider supporting RWI TODAY, CLICK HERE for info on how to subscribe.
See more
See less
Breitling rep water resistance
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Hey. Someone can tell me how waterproof top quality Breitling reps can bee ? I saw in fewer websites that there 50 meters. But i know that is not really 50 meters . From yore experience please.
    #2
    If you are going to go diving or swiming you should have the watch tested by a local watchmaker or buy a tester for $140 and learn to test your own watches. Never trust the factory test.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Comment
      #3
      I have two Breitlings from GF, one Avenger Bandit and one Avenger GMT. Both watches have been waterproofed and tested to 10 bar (100m) by my watchsmith, so they can be pretty preassure resistant.
      Skickat från min iPhone med Tapatalk
      Comment
        #4
        Im planning to get the avenger gmt too . If the watch already has screw crown and rubber band . What swatchsmith can add to the watch to sealed it iven more ? Im planing to go with the watch to light swimming in the pool in the worst case .
        Comment
          #5
          You can always get some silicone grease and grease the gaskets by yourself. I have done that to some of my watches. I also have an inexpensive preassure tester I bought on eBay. With that I can test the watches to 6bar (60m) before I go swimming with them.
          Comment
            #6
            If a watch is designed to be waterproof to a 100m or more the most common reasons it would leak is that someone has been careless putting it together. A broken, missing or kinked o-ring, a piece of hair or lint in the wrong place or an improperly greased o-ring could cause a leak. Anyone with a little effort can learn how to fix this sort of thing. First, you just test it. Most of the time it will pass and then there is no need to worry or do anything more. If it doesn't pass then the watch case back gets taken off and and you figure out why it is leaking and fix that.
            Really... ....... :P
            Comment
              #7
              All of my Breitling reps were good to 6 atm right out of the box (aside from my navitimer world that will never see any water). That being said, I still always regrease the case back gasket every time I open one up.
              As for swimming, I leave my reps high and dry and swim with my gshocks. No point risking $300 on user error when I have watches specifically designed for water resistance/extreme duty.
              Comment
              Working...
              X
