SW200 problem with ratchet wheel
MBvHoven
266
One week ago I was really happy to receive my new PP Aquanaut with SW200 movement. The watch is a real stunner and the movement was (and for now still is) an extremely accurate timekeeper.
I was over the moon with the watch, but started to worry a bit when I stumbled upon this thread on RWG:
http://rwg.cc/topic/140880-be-careful-with-the-sw200-based-models/
In the thread problems with the SW200 movement are discussed regarding teeth stripping on the ratchet wheel.
Mine seemed fine at first, but today I noticed this:
One teeth broken off, and it's a matter of time before more follow... [emoji32]
My question, and I would really appreciate your advise on this, what do I do? Do contact the TD (Toro) about this, or do I send it to a watchsmith, or do I wait for the damage to accumulate???
Sent from the RWI mobile app
Raddave
Administrator
66,221
17,217
Fix it asap........here is the reason...that tooth is somewhere , and the more that float around the movement , the more damage could be inflicted
MBvHoven
266
Thanks for that!
I'm a total noob when it comes to watch repairs. How does one go about sending a watch for repairs? Would any watchsmith be able to fix this? What would they charge?
unreformed66
165
19
United States, Ohio
Replacing the ratchet wheel is a 10 minute job unless something goes wrong. Pull the rotor, pull the self winding bridge, pull the ratchet wheel, reassemble with new part. And Raddave is 100% correct that you don't want to let this go. That tooth is rattling around down in there somewhere and will cause trouble. Let the watch run down and don't wind it again until you get it fixed. This might be a chance to see if a genuine ETA ratchet wheel will fit. I'm betting that it will. The cost of the repair shouldn't be much, I doubt you could pay the shipping to China and back for what the repair would cost.
MBvHoven
266
After doing some research, I found the following solution:
http://www.sellita.ch/images/stories/documents/IS05_evolution_calibre_SW200_vers_SW200-1.pdf
It is basically an upgrade from sw200 to se200-1, and it involves replacement of three wheels, including the ratchet wheel. I sent my watch off to Chris and he has done the fix! Can't wait to receive my "upgraded" watch!
unreformed66
165
19
United States, Ohio
Good deal! I didn't know that Selitta had updated the winding pieces, thanks for posting that information.
