Speedy parts
GFlansburg
641
Have a manual wind speedmaster moonwatch coming in from one of the TDs, but have a couple of questions.
1. Where can I source a domed Hesalite, and which size fits?
2. Im looking for a leather band, brown or black. Anyone have any recomendations for this watch specifically?
Cheers
GFlansburg
641
Thanks Mark. Yeah I had a look through there, and ive seen some on ebay that say they work with the watch, but I would appreciate some clarification from someone who has done it before pulling the trigger.
Btw, did you end up getting your pre-moon?
Edit:
Ah, scratch that, saw your post. Looks great.
markh
1,778
I actually have 3 of them. I got the quartz, the 21j and the manual wind ("Lemania").
Wish I could combine parts from all 3 to make a really nice rep. Not sure what's compatible with what though.
GFlansburg
641
Yeah thats tough, need a good dial, good plexi, and proper caseback. Gen dosnt have blue screws either.
Five of Clubs
866
The gen hesalite won't fit the manual wind rep. The next best thing is a 34.0mm Sternkreuz HW plexi that is available from Cousins UK. (Check out MarkH's Pre-moon thread where I have posted pictures of this). Remove the original sapphire and gasket, then glue in the slightly undersized plexi. It has to be done this way because the bezel insert has a smaller diameter than the bezel itself where the crystal sits.
Regarding straps, most of the gen guys like the curved-end Hirsch Medici availabe in two browns and black. If you want a vintage style strap, check out the offerings of the strap makers here at RWI. Any of them can make a strap to fit the Speedy. I especially like Donerix and Gunny straps because I've owned them and can verify the quality is terrific.
I hope that helps!
Five of Clubs
866
Nope, that is an HWS and you want an HW. The HWS has a weird step that doesn't look that good once installed.
Regarding the size, 34.0mm was correct for the manual wind rep that I owned. According to MarkH, he had a manual wind rep with a different size case so the plexi might not work on that one. I would pop the crystal out and measure the inner bezel diameter where the crystal sits to be sure (without the gasket).
