Santos xxxl chrono help
rg21044
90
I have a chrono santos xxxl. The minute subdials has some slight play in the hand. It functions...keeps time and resets....the problem is that it moves about a mm or two from the indices depending on my wrist position. What, if anything can I do about this? Anyone have a similar problem? Thanks.
carlton
3,084
Do you mean that your chrono minute hands move by itself in between 0 to 1 min marker by the position of the watch without activate the chrono?
If this is what you mean then it is quite common for chrono movement as most of the rep chrono watch do have this issue, at least for me it does.
rg21044
90
Yes that's what it does only backward between the 29 and the 30. Is there no fix for this. Tighten the hand somehow? And no not xxxl just xxl.
