Hey guys, I just picked up an explorer ii which has a few things that are bothering me.
- bezel is slightly off center
- rehaut is slightly off center (Rolex engraving not lining up straight)
- cyclops is crooked
- crystal is a bit off center (LEC is not straight on at 6)
- DW is a bit off center
The DW will just need to be upgraded to a better one.
I figure the cyclops and crystal are easy enough to fix. Seen a few vids on removing cyclops with heat and then reattaching with UV glue. Also can pop out the crystal to realign.
For the rehaut and bezel though, I'm trying to figure out how to remove. I can't seem to find anything on removing a non-rotating bezel, and I tried the standard pry tool already with no luck. Anyone have any tips on that?
Same with the inner ring. Haven't really done an in depth search for this yet but maybe someone can chime in if they've already done it.
Any help is appreciated. Thanks guys.
