Newb question. I'm thinking of buying a Santoss 100 or a Calibre. If I wanted to change the strap on either of these, am I able to order something from a site like www.panatime.com? Will only certain straps work with certain watches? Thanks.
The santos is very specific on the strap because of the cut and thickness of the strap at the lugs. The calibre should be good as long as you source the correct buckle and your able to get the right size hope that helps.
