Quartz movement battery replacement help
Karbon74
Pika Factory
9,701
18,623
EU - Kalos Region
Thanks man. Much appreciated.
also connecting you to @2005 Seadweller who is on the same journey as you, one step ahead
Reactions: Dave2302
Marclnd
96
35
Thank you
Reactions: Dave2302
Marclnd
96
35
That’s a great idea.
Here is an easy, cheap set
Nautilus Watch Case 39mm NH38 Watch Case Sapphire Mirror PP Case Kit for NH35/4R/NH38 Movement Watch Modification Repair Parts
You will only need a NH35 movement.
Another much better option that’s a little bit more expensive is to buy a 5513 or 14060 set from Raffles
This is the link to the case. There is an email address on the home page. You can write to him and ask for :
A complete set for a 5513 to be built with a NH38
By the way…I did some shopping on AliExpress, and I am now waiting to receive dial, movement, hands, etc…I will post my first creation here…Wish me luck. :)
Marclnd
96
35
My first creation…and I thought it was going to take longer. A few points:
- putting the seconds hand was the most difficult part for me.
- the movement is nh36 with day/date, however I could not find a case with day/date magnifier. Any tips/guidance here?
- the strap I think it is too big, but that‘a what I had at home.
- I ruined a bit the dial as I didn’t cover the dial when I removed the hands a few times whilst I was learning how to position them (although I had a dial cover to use - just not enough patience :))
- Happy to hear comments and tips from the experts. Thank you.
Marclnd
96
35
Nice job
Traditionally, a day day like this will not have a cyclops. Just a flat crystal
Thanks man. Ah, that’s why I could not find one with a larger cyclope 😂😂
Can I change just the crystal? Or is it easier to buy a new case/crystal?
Reactions: Dave2302
Karbon74
Pika Factory
9,701
18,623
EU - Kalos Region
It depends on the price of the case and your objective
If that’s a cheap case, just buy another one.
If it’s relatively more expensive or that you want to practice a crystal change, then do it
I would personally use another case.
I would also suggest using baton hands rather than mercedes on this build.
Marclnd
96
35
Thank you. Makes sense. I wanted to practice the change of a crystal, since I already have to change it, but perhaps it is not worth it in this case…
Thanks for the suggestion. Do you mean these -
- with baton hands? Thank you
Marclnd
96
35
Another question. I installed the hands, however when I knock the watch, the minutes hand moves…I have already checked and they seem to be installed correctly. Can it be that I broke the minutes hand and now doesn’t stay put as it should?
