problem with 2836 (crown and adjustment)
Sommelier36
76
EUROPEAN
Hello. I have a problem with the movement of the axis that from the crown enters the hole and adjusts the date and time. it seems that it turns badly that it does not move the gears. in fact if I turn the crown nothing happens. I post pictures of the problem, but I don't understand
Plaasbaas
IWC-hoarder and PAM-hunter
2,684
6,122
I can't really make out what is going on from your pictures, but maybe you can find the cause of your problem yourself by watching the tutorial below and spend close attention to what he does. It is a 2824 movement, but the keyless works looks very much the same.
If you want to jump directly to the assembly of the keyless works, jump to around minute 12:00.
How to service an automatic watch ETA 2824 Watch repair tutorial - YouTube
