Panerai case opener
Roeod4
4,073
11
Hmmm that is different. I still think I prefer the blue plastic ones, less likely to scratch the case up.
geopatr69
797
:D :D I have one. It is great. Great fit and finish. Works well and looks cool :lol: :lol:
takashi
11,500
looks great to me... If you want to avoid the scratches, I would suggest applying some Blutack on the edge. Nonetheless, I'd still stick to Jaxa caseback opener.
panman8888
259
where do you get teh blue plastic one you refer to?
thanks!
Roeod4
4,073
11
Re: where do you get teh blue plastic one you refer to?
panman8888 said:
thanks!
I see them on ebay all the time. I think PT or Narikaa had them at one point too.
You may want to ask Birdman, he is the tool guy and can probably get some.
bigbadbrad
1,647
Looks good - but I am sceptical about the claim that it doesn't scratch.
-- BBB
gioarmani7428
1,399
41
Wrote that eBay member & Birdman--no luck on the plastic availability. Any other suggestions?
geopatr69
797
I have this aluminum one and works great. It is a piece of art. :wink:
higgy
3,410
I use one of the rubber friction type with a little sticky stuff..... :shock: Haven't met a caseback yet that I couldn't get off. And I do everything "onehanded"........ :D
Higgy 8)
Roeod4
4,073
11
This is the one I was referring too.
There are none listed at the moment but do a search for "44mm case opener"
I generally use one of these
D
d4m.test
Guest
enzo said:
problem with all of these is they are 44mm only ...
Now I find 47mm casebacks are more an issue than 44mms so I am going to wait for the tool that does both, or at least gives the option to buy one size or the other ...
(Most 44mm casebacks will fit a JAXA or other conventional 3 pin removal tool. It is those 127, 217, 203 and Vintage cases that always max out on the settings. With the PAM249, 232 and other 47mms a good, discount priced 47mm case removal tool is the next grail object ... )
The seller of the aluminum gizmo says in his Ebay description a 40mm and 47mm to follow.
We'll see..
D
d4m.test
Guest
enzo said:
$ X 3 - yep it's still a gift item for me, just waiting for my gift :)
Well, I'm into giving esp around Christmas....
I have a certain SF240 ready enzo'ed Dial on my list.. :wink:
