Wow. Was it the Swiss 7750, or Asian 7750, or manual version?vdubpower said:had a 212 explode, no such fucking thing as sapphire, those crooked liar dealers,
hooligan said:Lumpy, that sucks. If you see the other thread about TWP's mini-fiddy, you'll see that I'm trying to source a plexi domed crystal for mine. Could you, by chance, get an accurate measurement of the diameter of the inside of the case where the crystal mounts? This would help us all find replacement parts. There has been some speculation that since the mini-Fiddy case uses a bigger dial than most 44mm cases, it may require a larger crystal, too.
Please get a measurement if you can.
Thanks!
piratedzeus said:What about PMing TWP?
lumpyone said:hooligan said:Lumpy, that sucks. If you see the other thread about TWP's mini-fiddy, you'll see that I'm trying to source a plexi domed crystal for mine. Could you, by chance, get an accurate measurement of the diameter of the inside of the case where the crystal mounts? This would help us all find replacement parts. There has been some speculation that since the mini-Fiddy case uses a bigger dial than most 44mm cases, it may require a larger crystal, too.
Thanks!
i do not have a micrometer at hand but using a precision rule it is 37mm inside.
if you have any luck finding plexi crystals please pm me. ill buy some as i have another ticking time bomb here.
my other mini fiddy is sure to go off soon too
lumpy
edit:
so looking at the cousins site i suppose i would order a 37mm and a 36.8 just in case.
THANX sssurfer
