Keyless work fix [Part 1: 6497]
Wiz
6,708
21
Here is a little guide on how to fix a jammed keyless work on your 6497.
There already are many turorials on the internet on how to open the case, remove the dial, ..., so we’ll start once all of this is done.
Here is what you should now be looking at.
Most keyless work issues are caused either because a part is broken, or because the yoke that is supposed to sit in a groove is not sitting there anymore.
The left arrow shows the groove, and the right arrow shows the yoke. As you can see, on this example the lever is out of the groove, and the movement is experiencing a keyless work malfunction.
Start by removing the screw of the setting lever jumper and the setting lever jumper itself.
Be carefull while removing the yoke spring, it tends to jump quite easily. Hold it with a stick while you grab it with your tweezers.
Now you can clearly see the yoke out of its groove.
Remove the yoke.
Push the sliding pinnion back against the winding pinnion.
Now return the movement and unscrew the setting lever screw.
The following part (the setting lever) will fall off. Make sure it’s not damaged, cracked, ....
Then replace the setting lever, hold it with a stick and screw from behind.
Setting lever back in place.
Replace the yoke, properly positionned in the grove of the sliding pinion.
Replace the yoke spring. Use your stick to maintain the round part while you install the tips with your tweezers.
Put the setting lever jumper back in place. To be sure it’s correctly positionned, look at the 3 red arrows.
Replace the setting lever jumper screw, and it’s all done!
Reactions: Major Tom
co-axial
23,226
Thanks Wiz!
Easy to do with this guidance (done this myself often enough).
numero2
2,003
305
FR
Good works as usually. It Will help the communauty.
Thanks.
Brunik
26/9/12
57
Greaat job
Enviado desde mi GT-I9300 usando Tapatalk 2
DirtyHarry62
2/11/12
44
Thank you for the tutorial. Great pics, simple and clear explanations, truly helpful for those of us trying to learn more.
bc1221
Put Some Respect On My Name
30/4/14
4,079
454
i learned this the hard way yesterday.
its good to know that i can fix a keyless works on a 6497 though.
i think that damn spring went flying across the room a few times :lol:
Major Tom
565
103
Thanks buddy, little screw holding the stem disengaged, i.e. screwed it a little out too far. Your tutorial helped me out a lot. Cheers!!!
Jamestof007
Horology Curious
28/11/23
17
Thanks a lot for this tutorial !
There is a short list somewhere for all tools that i need for work on my watch and purchase link ?
