Hi Guys!
I need some technical advice. A couple of days ago I noticed an issue with my H fac 000. First crown/stem seemed to "jump" sometimes when winding. Than I wasn't able to set time. I could turn the crown in setting position but sliding pinion wouldn't engage with setting wheel.
I did some reading and decided to give it a try and reset keyless by myself.
Now, after dis- and reassembling keyless work three times and spending two hours searching through the whole carpet looking for that goddamn yoke spring...
I'm pretty sure everything is put together correctly. Time setting works perfect, but I can't wind it. Sliding pinion moves towards winding pinion like it should when I put crown into winding position, but it doesn't engage fully. It doesn't "grab" it... I can't see any damage on pinions teeth.
Is there anything obvious I am missing?
Any advice highly appreciated.
