How to fix a recessed Cannon Pinion.
cybee
11,134
29
This is the first cannon pin change I have done so I decided to take a few pics along the way. If you enjoy tinkering with watches it is a lot of fun but there are a couple of things to watch out for in the process...OK on with the show.
Remove the crown guard and stem from the watch then remove the movement from the case. There are other tutorials that already show how to do this.
First we remove the hands from the watch:
This dial just lifted off the movement:
Remove the keyless works cover screw:
Remove the keyless cover: Be careful because the set spring underneath can fly away very easily.
CAUTION: Now remove 'set spring'. It is the U-shaped spring in the photo. See how the spring fits next to the 'clutch lever'.
Be very careful not to let the spring get away from you. The reason we remove the keyless cover and spring is to get to the minute wheel for removal and we remove the minute wheel so we do not risk damaging its teeth when we seat the new cannon pinion.
Now remove the 'hour wheel' and its foil:
Now we can remove the minute wheel:
Parts are safely stored:
Now we are ready to remove the short cannon pin:
Here is the correct tool to do it with. It is a Bergeon #2 hands and cannon pin puller. Regular pliers can be used but this is the correct tool for the job:
Place puller over pin:
...and gently squeeze the sides to lift the cannon pin off:
...cannon pin removed:
Here is a shot of the short pin next to the larger one we will put on:
Place the new pin in position:
...and firmly press downward until you hear it seat. You will know when it is seated properly, it will make a nice click. I used the end of my tweezers. A press would be ideal for this part but sometimes we must make do with what we have.
Now replace the minute wheel back on:
minute wheel in place:
Here is the short hour wheel next to the new larger hour wheel. The large hour wheel comes with cannon pin as a set.
Take the foil from the short wheel and place onto the taller wheel:
Hour wheel in place:
Now its time to put the set spring back in. Be very careful because it can get away and make sure it butts up against the clutch lever:
Set spring in position:
Replace the keyless cover and screw:
Place the dial on:
Now we put the hands back on...With the larger cannon pin the hour hand should fit fine, but the minute hand will need to be filed down in order to fit on. I invert the hand on a flat surface and file down to correct size with a jeweler's file. Take your time, file a little then test for fit. File until the correct fit is achieved:
Jeweler's file for filing down the flange on the minute hand:
Hour and second hand placed on:
Now the filed down minute hand is placed on: The minute hand could use just a little more filing down, but much improved.
Now I clean off dial smudges with some rodico putty:
Maybe still not perfect but much better:
...and just for fun we will finish with a pic of the real thing. Thanks for viewing and good luck. :D
R2D4
Admin
14,905
42
Looks Great Cybee. This makes me want to get a Panerai Rep even more. Good Going you Master of Sales! :D
LegendofSpeed
Put Some Respect On My Name
4/5/06
5,722
Great tutorial.... I especially liked how you showed how you can file the hand down to make it work with the tall canon pin...
Some of you out there have Panerai's with tall canon pins already and don't know it! If you find that you do upon disassembly, you can file down the hand and make it work like this... the last few asian movement Panerai's I have bought have had a tall canon pin but with hands that had a flange that was too long... just file down, or us a set of DSN hands (pre-filed down and lumed for you) and you're good to go!
guru
11,642
1,229
great post cybee, thx a lot, next time I will try it. Didn't know that I need a new hour wheel too.
no_one
359
A 'few ' pics... It's a step by step tutorial.
Very nice, thanks cybee. I'll definitely be referring to this.
konigwolf
387
We definitely need more posts like this, seen all those pics I feel confident in doing the same mod myself.
cybee
11,134
29
That would definitely save a lot of work... I was afraid to file the hand down any more because it was really starting to look flat, not a lot of room left to put on the post.
I have only seen this tutorial twice on another board and figured we needed to have one here. What really impresses me is that the Asian 6497 is built very well and so far every Eta part I have tried putting on fits, except for the screws. The Eta screws seem to be slilghtly different and will not fit on the bridges. Also the teeth on some of the gears are smaller than Eta gears....oh well too much fun... thanks for the kind words guys. :D
lan61t
838
Worth of a sticky - my 0.02c
I've been looking for this tutorial, and now i found it, GREAT job cybee :)
Industril
12/5/09
25
Just wondering if anyone knew....what's the purpose of the foil for the hour wheel?
Cheers.
R2D4
Admin
14,905
42
The foil, I believe, serves 2 purposes. Someone can correct me if I am mistaken. :wink: 1. It has a special cupped shape so that when the dial is on top of it, it acts like a spring to keep any play in the hour wheel at bay. 2. It keeps the dial from laying directly over the hour wheel which could cause direct frictional contact.
I did my best. :D
MReplica
Trusted Dealer
Trusted Dealer
31/3/09
329
Thank you cybee, this turtorial helps me a lot in canno pinion. Great job!
cybee
11,134
29
Very glad to hear it helped. Thanks littlepopeye.
acharria
26/10/09
5,147
Cybee, I just read this thread, Im new Here, and these Pics help me to learn a lot.
Maybe some day i may do so in my watches. LOL
Thanks a lot Cybee.
daytona4me
sorry who are
Administrator
13,585
10,008
cybee,
might I add:
Some people might ask, why remove the minute wheel, you would not have as much to disassemble,
If you push the new CP down on top of the minute wheel and it is not aligned correctly, you may chip off a tooth on the minute wheel or damage it possibly causing debris that will seize up your watch.
It should be done exactly as cybee has shown!
Good tutorial!
