SurePictures of the clasp would help to provide you the correct information.
Thank you, will check it out. But the clasp width is 18mm, are u sure it´s 17mm?Search for 17mm flip lock clasp spring bars for 126660 model watches. That's what you're looking for. The thing is, I'm not sure if there's a sheath that goes around the bar itself or if the spring bar itself is coverend in the DLC coating for the Blaken models.
I know that the spring bar will be the 17mm though.
That 18mm measurement is the width when measured to the outside surface of the clasp, the inside of the clasp is 17mm (where the springbar holes are located.)Thank you, will check it out. But the clasp width is 18mm, are u sure it´s 17mm?
Ok, sorry im pretty new to thisThat 18mm measurement is the width when measured to the outside surface of the clasp, the inside of the clasp is 17mm (where the springbar holes are located.)
But I'll probably have to press the fliplock together a bit, see that it's not completely straight, so then your measurements are correct
I’m curious as to how exactly this is measured as well…perhaps one of the OG’s will chime in and let us know, bc this is a perfectly valid question!!!Still cant find out exactly what spring bar i need…
Yeah it is, and i wonder if there is some site where people can buy spare parts for replicas? Would be cool.I’m curious as to how exactly this is measured as well…perhaps one of the OG’s will chime in and let us know, bc this is a perfectly valid question!!!
Thanks, will check it!Just search for a 17mm springbar. I would also get a 16mm in case there is some variance in how they are measured. For example a 20mm springbar is not 20mm, it's longer so the tips can extend into lug detents or holes. Your fliplock detents might be less deep by comparison and a compressed 17mm bar may not fit.
I ordered it, both 16mm and 17mm. Diameter 1,5mm, i hope it´s not 1,78 in diameter because they had that too, but i think 1,5mm is the right measure.Thanks, will check it!
