Guide on Genuine Dial Swap
memoismemo
Horology Curious
29/10/19
Yesss..
I also need information to dial swap datejust 31mm..
Is there any way to do??
nautilus1956
30/10/18
26
Hi, this is a question about gen Rolex, I was wondering if somebody can help me out.
I want to create a custom enamel dial for a new Rolex. The problem is that the enamel dial is much thicker than the original one, around 1mm. The enamel dial will not have a calendar window, so the calendar parts can be removed. Does somebody know if I can use Datejust for this? Is there a Rolex in the current collection which can take a 1mm thick dial with no case modification? Somebody told me that Milgauss can. Thank you in advance.
John1
172
17
How are you going to make the hands fit with a thicker dial?
W47chl0v3r
PM for 5402 inquiries
1,109
722
Hopefully someone has run into this issue before me and can shed some light on it.
I have a VC drivers watch and a gen dial and want to do a dial swap. The problem is that the sec@3 pinion isn't 100% aligned between the dials. It is like 0.7mm off. See pics. What are my options?
legend
slaughterer62
Tagging some people with experience here.
GuillermoUgarte
104
84
California for now
ZENITH EL PRIMERO: Anyone have experience on finding a chronometer case with (preferably old-school piston) pushers to be a perfect fit for a gen 36.5mm Zenith El Primero chronometer dial with subregisters at 3 and 9? And which Asian automatic movement would work for such a dial that to further complicate matters has a date window at 4:30?
