Easy fix for quartz movt. watches that don't reset to zero
rhp1462
6,617
If your watch is not resetting to zero do the following. No tools needed. Works on most quartz chrono.
It is a very easy fix.
See the pic here. There are two pushers and a crown. There is a pusher at 2 o'clock and one at 4 o'clock.
1. Pull the crown.
2. Press on pusher at 4. Keep pushing it till it goes to zero. It should move in one second increments.
3. Once you are on desired marker, leave everything alone.
4. Push the crown back in.
5. It should be fixed.
6. Enjoy your quartz. If it is a rep that is suppose to be auto and it is quartz, don't use chrono in front of your friends. It is a dead giveaway.
D
d4m.test
Guest
Very informative and helpful post. Will try this out when the occasion comes. Thx for sharing
Raddave
Administrator
66,236
17,238
Hope it worked for ya. This works for most watches with ETA, seiko and Citizen movements.
And Miyota and Ronda....
Nice post bro !
AlanW3010
531
On my Breitling quartz, I had to keep pushing the 2 button. It moved in 1 second increments. Watch saved!!!!!! Thank you.
