DSN PAM111H Winding Problems.
Tony007
2/11/09
Can I first say, I am enjoying the watch ever since DSN sent it in Dec 09. Full modded workmanship is top class A+
I recently havent been able to wind the movement as much as when he first sent it?
In the beginning I used to be able wind the movement 30-32 times and get around 45-48 hours reserve.
Recently though I can only wind the movement only about 18-20 times before full resistance is felt in the winding. This only gives 18 hours max reserve before the time stops.
Is this issue common after a few months, as I thought the movement was solid and reliable?
Is there a fix you might know that might be able to do to get the movement to wind 30 times again and keep a longer reserve?
Please can you officienados help
A happy customer.
PS sorry bout the image size below! just click it to view via image shack...
SPEC
44mm pam steel case
sapphire with ar
swiss dagger swan neck 6497 h movt
superlumed sandwich dial and matching hands
hooligan
8,332
No, not a common issue. Something is definitely wrong with your movement. Have it looked at by a watchmaker.
