davidsen's HIGH CANNON PIN INSTALLED, no problems
sexybeast
1,266
what does it mean and just wondering why this is a good thing compared to everybody elses watches or do other vendor watches have the same feature?
sexybeast
1,266
enzo said:
It is one of the most COMMON visual errors on PANERAI REPs in general. The Cannon pin is the bit that holds the MINUTE hand, and on reps the part is too short and so it doesn't flush with the hand and you can spot it at about a good 3 metres once you know about it . . .
( Want someone to know you are wearing a rep without even close scrutiny, then walk around with a recessed cannon ... )
Check out DIY section here and there is a 'lesson' in tutorials which covers the FIX and thus illustrates the issue.
LOOKING for that telltale shadow in pictures is the fastest way to determine if an auction is REP or GEN
thanks enzo.........
