116622 case same for 3135 and 2824?
Rbrobson
4/9/19
31
Hey all - I’ve read that the Noob and JF 40mm (6 digit) Yacht master cases are the same for a clone 3135 movement and A2824.
Does anyone know if the same is true for the ARF version of the Yacht-Master (116622).
Specifically I am curious if I can drop a VR3135 movement into an ARF Yacht-Master that originally housed an A2824.
masterpiece777
493
272
EUROPE
Are you know if it’s true that a 2824 case takes a vr3135 movement?
Verzonden vanaf mijn iPhone met RWI
Nikz19
Watchmaker / Modder
Vendor (Watch Repair)
1,885
2,846
No.
Sadly, I have one here and while the movement fits the case just fine the stem won’t align correctly with the tube. I ended up ordering a correct 3135 case.
pompompurin
:3
5,115
3,213
Hong Kong
ARF 2824-2 watches, at least for the ARF Datejust 41 and ARF Sea Dweller 126600, have thick DWOs and thick dial spacers which make the overall stem height quite low.
I managed to fit a 2836-2 inside an ARF Sea Dweller 126600 (which originally used a 2824-2 movement) because the stem height was that low.
