Movement swap questions, plz help!
JPR705
Looking Around
25/8/17
I recently purchased a ZF Black Bay rep and would like to swap to a genuine swiss eta 2824 but I am concerned if the hands will fit the new movement. I read about it being a h2 pinion and am concerned it will not work. I will be having a watchmaker do the work but just want to know in advance of any possible problems. Any help or guidance on this is appreciated
Drr80
515
102
El paso, TX
If its a asian eta clone (a2824)then yes. Pretty easy swap with the right tools and steady hands. Sausage fingers need not try :p
ado213
712
184
Off memory, black bay hands have extended hand tubes to compensate for the clone movement not having #4 pinions on it, so your swiss 2824 will be a direct swap
Reactions: d4v3
8a8b15
22/8/18
62
I swapped the 2836 in my noob v8. Easy job, but I can't stress enough to invest in proper tools... polished hands scratch so easy.
fireice2
107
Hi just to add to the OP query, is this direct swap also applicable with the ZF bb58 with 2824?
Rx4Time
Supporter, Panerai lover
10,970
7,804
2824 Asian to ETA is a direct swap....
