1680 colour of indexes
Lovegmt73
295
186
Hello mate, I would like to age a bit the indexes, I know this can be done with paint or coffee, this will make the darker, are there any trick to make them lighter and reduce the lume effect?
I’m thinking at milk or white paint for example
Raddave
Administrator
66,119
17,074
a buddy of mine uses water color paint
Raddave
Administrator
66,119
17,074
well if you are reluming you can always tint the lume with a magic marker , put a spot of the magic marker in you mixing surface , before you add your binder , the binder will mix with the ink
Reactions: rwacc
Lovegmt73
295
186
I did it before with coffee, but I would like to try to make indexes more white to reduce the lume effect that is too much for a vintage, the only matter is that must be accurate otherwise the white will be visible on the black dial
Lovegmt73
295
186
See how white is the GEN
