Announcement
Collapse
No announcement yet.
Screws for mounting VR3135 movement into genuine rolex case
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    The title says most of it. I need to mount a VR 3135 into a genuine 15200 case, and there is no screws includede with the movement.
    What screws can you use for mounting the movement?
    Thanks in advance
    #2
    https://www.ebay.com/itm/Rolex-3135-...AAAOSw1UFdBvdM
    Comment
      #3
      https://www.cousinsuk.com/product/screws-case-clamp
      Comment
        #4
        Thank you so muhc irishjohn and oldtools
        Comment
          #5
          Just remember, those screws screw in the opposite direction. I completely forgot about that the first time I tried screwing down on a gen spec movement/TC’s case thing. It was driving me crazy (no pun intended) until I remembered that that screw is supposed to turn the opposite direction.
          Good luck
          Comment
            #6
            Haha thank you for the heads up mate!
            Sendt fra min SM-G986B med Tapatalk
            Comment
              #7
              Good luck
              It’s so funny you say this... I had the EXACT same issue, nearly went mad lol... Eventually 30 minutes in I realized they were meant to apply pressure from the BOTTOM UP. You basically screw them in all the way first, then when you unscrew it, the rising height of the screw locks the movement in place.
              Comment
                #8
                Yeah it is not an easy task at first haha, you really don't think about it that way
                Comment
                Working...
                X
