Help! jubilee Clasp is wayyyy to tight
d100591
Patek addict
17/9/17
84
24
Hi i can’t really open or close the clasp of the rolex jubilee is there a way to fix that?
Sent from the RWI App
RepPossessed
The UK dealer
Trusted Dealer
10/11/15
7,286
1,645
Uk
you can adjust them with a tool
A very very fine bending of the bottom bar of the clasp or straightening of the top bar will loosen it
like if you straighten the top bar it would make it longer and thus take the hook further away from the latch
you can see a tutorial on you tube
but its a fine fine adjustment, dont try it yourself if you dont know what you are doing
Reactions: d100591
tripdog
Super Moderator
22,567
17,984
^^ What he said, very slightly straighten the narrower clasp blade.
Reactions: d100591
d100591
Patek addict
17/9/17
84
24
Ok i have never done it before but it shouldn’t be so hard to bend it a little right ????
Gesendet von iPhone mit RWI
tripdog
Super Moderator
22,567
17,984
Just apply light pressure, holding the curved side towards you, apply a little pressure with your thumbs to very lightly straighten the curve - check if it's worked or not, if not apply a little more pressure the next time.
Reactions: d100591
d100591
Patek addict
17/9/17
84
24
I tried it and it worked perfectly thank you very much :)
d100591
Patek addict
17/9/17
84
24
Thank you also yall rly helped me :) love this forum
