Remove superglue from bezel,
XpanzerX
1,043
488
So I got a bp 16600 and previous owner glued in a fat 4 bezel insert, I love the bezel insert but the bezel wont rotate.... I assume he got glue behind the insert and now the bezel wont turn. Any ideas on how to remedy this without hurting the insert? I know acetone works but dont wan a mess up the insert.
Sent from my SM-N950U using Tapatalk
tripdog
Super Moderator
22,482
17,775
Just lever the bezel ring off the case, then prise the insert out. There was probably some residual oils on the parts before he glued them together which means the bond won't be very strong.
Reactions: XpanzerX
XpanzerX
1,043
488
Is it pretty easy to do on the bp SD? like a case knife at 7 o'clock and pop it off? Haven't messed with this model before
tripdog
Super Moderator
22,482
17,775
Yes, t lever it off gently with a knife, watch out for the click spring inside at 11 o'clock.
