Announcement
Collapse
No announcement yet.
2824-2 date wheel issues
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    Hi there guys
    Recently recieved a Noob Ingenieur and have noticed the date wheel sits quite low in the cut out between numbers 1 - 12 before sitting central 13 onwards. Is this a dodgy date wheel or could there be a mechanical issue that can be repaired?
    Pics below
    #2
    Date wheel was applied crooked. Would need to be removed and realigned.
    Comment
      #3
      Yep.
      Looks like it could be a easy fix if you know how to remove the movement, hands and dial of the watch. The DWO just seems to be a little higher than it should be. You should be able to just move the DWO counter clockwise slightly. You just have to make sure it’s on there good. Would recommend some slow setting adhesive that does not expand.
      Comment
        #4
        Originally posted by Bokthoi View Post
        Hi there guys
        Pics below
        I can help out if you are USA based.
        Pm me
        Comment
        Working...
        X
