AFR Milgauss Sapphir gasket stuck ???
Wolowizard
Horology Curious
10/6/21
Hello everyone, i've try to mod my arf milgauss with a green aliexpress sapphir, everything went fine until pressing of the new glass
it appears that the genuine arg gasket is stuck between the rolex internal insert (rolex+serial number engraved by laser), i've tried with thin tool, or boiling it into water to make it more extractable, and it was not succesful ...
any idea to remove it ? i will post pics soon.
Wolowizard
Horology Curious
10/6/21
(because i did'nt use the bezel pressing method by the way, and try to re-use the stucked gasket instead of the new provided)
i will post pics of the stuck and now damaged gasket tomorrow
Wolowizard
Horology Curious
10/6/21
ok so i took a scalpel and try to remove a 2nd bezel like other rolex type on youtube tutorial and it was that , very tight, almost invisible ...
the green gasket is too stiff, i will try to soften it with hot water, i have to get a new saphir now :d
Reactions: oay62
Wolowizard
Horology Curious
10/6/21
So , iv'e bought another crystal, received two from aliexpress
the thing is : i dont believe that it is easy to change the crystal for an aftermarket one (maybe the original is ok)
the green gasket is bigger , i had to boil the gasket bezel and put the case with the crystal and gasket on, to the freezer
then my chinese crystal press was to cheap to apply a good amount of pressure so i used my grandpa vice
i know i am a butcher but only the result count :eek:
fixed is fixed
will do better pics later
Wolowizard
Horology Curious
10/6/21
fixed is fixed
Plaasbaas
IWC-hoarder and PAM-hunter
2,664
6,086
You seem to have used the power of Hulk, but no matter how you pulled through and can now enjoy your watch. I'm glad for you, well wear Sir!
Thanks for the pics. I am also still learning and have struggled with a stubborn, pesky gasket and crystal myself.
