Well you would if you examined the LEC under high magnification - the Noob’s looks way better than the gen’s!i wonder if on blind test one would be able to notice the difference between gen crystal and rep one provided you changed the milky white gasket with a cousin <1$ one
What is the consensus for the best gasket/crystal for a 116520 daytona?
im hestitent of buying gen because im not sure its worth it
cheers!
I did this mod yesterday, I used a cousins gasket.. I did a dial swap at the same time. I don't think you need to change the crystal.
