VS3235 parts?
WatchSmith.US
-- Watchmaker --
Vendor (Watch Repair)
1,289
1,966
In my 3235s the gen balance and bridges show immediate improvement in accuracy and stability. Auto wind module is also a very nice upgrade. I have more parts planned but they are probably less essential.
Pietros
264
254
Please excuse my ignorance but are the gen balance & bridges 2 separate parts?
Did you use a gen pallet fork too?
Sent from the RWI App
maxracingshox
2,581
286
While they technically can be separated, retrofitting one of them to a clone movement mandates that you fit the other one as well. So you might as well see them as a unit.
Pietros
264
254
Thanks, so balance, bridges & pallet fork are 3 separate parts?
WatchSmith.US
-- Watchmaker --
1,289
1,966
Yes, it will come in two parts and you have to connect the hairspring to the bridge. You’ll also have to regulate by adjusting the microstella nuts in the balance wheel. A timegrapher is a must.
i do have a gen pallet fork and escape wheel but haven’t installed them yet.
Pietros
264
254
Thanks for the info-just one more question-is a gen escape wheel a must if using a gen pallet fork?
watchservicesny
1,275
754
Why you want to use gen pallet fork?
WatchSmith.US
-- Watchmaker --
1,289
1,966
I am told that you must install both gen pallet fork and gen escape wheel. One member attempted just the gen pallet fork and reported that it wouldn't run, and had to install gen escape wheel.
Reactions: Pietros
32,773
59,002
It was actually the other way around. The top pinion on my rep escape wheel broke so rather than buy a whole new movement I bought a gen escape wheel. I suspected it might not play well with the rep pallet fork but tried it anyway. It did not run and I ended up having to install the gen pallet fork also.
Pietros
264
254
I’m thinking gen balance, bridge, escape wheel & pallet fork will be great upgrades in terms of accuracy, once properly regulated.
If the movement craps out at some point, they’re all transferable and retain value.
32,773
59,002
The escape wheel and pallet fork would not improve accuracy, that's the job of the balance wheel. The other parts were redesigned to improve efficiency, specifically to use less energy in operation thereby increasing power reserve. The VSF 3235 PR should be plenty long enough to make those parts upgrades unnecessary, unless you just want to go all out.
https://quillandpad.com/2019/11/19/...x-calibers-3135-and-3235-and-which-is-better/
Pietros
264
254
Well that’s saved me a few £££.
Thanks for the info!
Reactions: KJ2020
Patricdeen
INMATE
19/6/20
373
272
Iwo in Germania
That's a really cool post! I think I'm in. When I'm done, I probably rebuilt the entire movement and sunk 3000 buks xD
MSC19
867
948
Earth
Consider an autowind module instead of escape wheel and pallet fork...it will improve the PR of the movement.
Reactions: Pietros
EstebanMcQueen
14/3/22
65
32
Hi guys,
I hope Im posting the following in the right thread, otherwise please point me to the right thread as this was the closest thread I could find related to my questions.
Long story short, I dropped my VSF Submariner. I sent it to my watchmaker. His english is not the best but he said that the balance wheel and jewels broke. So, he will need to order the spared from China as they are not widely available for the VS3235. He then said: "I try.. to put jewels. But it's not last longer". Obviously this solution doesnt work for me either.
So, I was wondering if I could go genuine with the spares needed, I dont even know if he will be able to get the spares from China in this lifetime. Any watchmaker savants could let me know if this would be possible to fix with genuine parts? Or is it worth it at all?
Should I just get another VSF Sub and keep the broken one for future spares or a future franken project?
Any leads or any information that can help me is much appreciated guys. Ive also attached a pictured send from my watchmaker.
Thanks in advance 🙏
EstebanMcQueen
14/3/22
65
32
Anyone willing to point me in the right direction?
Hi guys,
Thanks in advance 🙏
