How to thin out Daytona 116520 arf
philheat16011992
65
29
PIEDMONT ITALY
hello everyone I apologize for my incorrect English but I am Italian and I use a translator. I bought a 116520 arf v2 which ootb in my opinion is really gorgeous! I just wanted to change the caseback and put a thinner one ... Can I mount the noob one without having to change anything else? if so, where can I buy it? or do I need to change rotor etc etc? Thank you all! :)
ZPfBTNanAAAAAElFTkSuQmCC
pompompurin
:3
5,118
3,217
Hong Kong
I didn't mod an ARF Daytona before, but if I recall correctly from what I read (please feel free to correct me), people generally did the following mods to get a thinner case-back:
1. Source and install a jf 23j Daytona case-back (which is thinner)
2. Remove the deco plate
3. Install a Swiss ETA 7750 rotor
guybythelake
299
122
Where can I 23j Daytona case-back?
32,773
59,003
Those are long out of production bro and only available M2M. But a Noob 4130 caseback will work also. You can ask a TD or check M2M sales.
Reactions: Ex-ki
glt69
Horology Curious
4/5/14
I have already done it, I received a few days ago the 7750 rotor complete with screw, I removed the decoplate but once the 23J case-back is installed the rotor does not turn because it touches the case-back.
How can I fix this?
thanks in advance for the advice…
srhoque
Put Some Respect On My Name
28/11/18
3,259
2,463
Install the OEM 7750 rotor (remove ARF deco plate) and put in a Noob caseback.
Doud
1,068
185
This is what I have done… but with 23J case back the rotor is stuck
Sent from the RWI App
I had the exact same issue when I did this mod. I sent it to Domi since I wanted to do a full service anyways and he said the issue was the 7750 rotor I had bought. He ordered the correct one and it worked perfectly.
glt69
Horology Curious
4/5/14
I will try to replace it… I hope it will work!!!
