Dear RWI community,
With the mods' approval, the aim of this post is to show someone how to spot differences between the genuine and replica Rolex Submariner watches - a guide with many ways to mark on your check-list in order to see whether you are looking at a genuine or a replica Rolex Submariner watch.
In this guide, you'll find genuine vs replica images linked for every step, which will help you notice the flaws on the counterfeit Submariners.
At the bottom of this post, we will paste a link to our full guide with the full ten steps on how to authenticate the Submariner. This information is, and will always be free for everybody. Therefore, your input and feedback (positive and negative) is highly appreciated, in order for us to get even more accurate with your help.
Without any further ado, let's jump in the guide:
Step 1: Check the lettering on your Rolex Submariner
For the second first of the guide on how to spot fake Rolex Submariner watches, we are going to inspect both the replica vs genuine Rolex Submariner watches for the lettering on the front side, on the dial.
First of all, let’s have a quick look at the reference Rolex Submariner replica vs authentic image in order to spot the flaws on the fake Submariner easier.
https://imgur.com/ffSvRJ6
At first sight, you might not see the differences between the genuine vs replica Rolex Submariner watches in the image above, but if you look closely and carefully, you can see how the fake watch has its text improperly font-weighted and positioned.
By improperly font-weighted, we mean that the replica Rolex Submariner watch has the letters in the “SWISS MADE” text looking too thick and a bit washed-out, compared to the letters met on the genuine Submariner watch.
Replica manufacturers must save up on costs with the production and the machines that they use, so they will often skip some details, or make them present on the watch, but not perfectly displayed / installed / engraved / written etc.
So, if you take a quick look at the genuine vs replica Rolex Submariner image again, you can see how the genuine Rolex watch has all of its letters at the same font-weight, unlike the fake watch.
With this being said, let’s have a look at a zoomed-in replica vs genuine Rolex Submariner image in order to spot the flaws with the placement on the replica Submariner easier, with a little help of the hand-emoji pointers.
https://imgur.com/FAlpNtl
In the Rolex Submariner genuine vs replica image above, we have pointed out how the fake Submariner Rolex watch has its “SWISS MADE” printings improperly aligned, as the “SWISS” text is placed too close to the tick which indicates the 30 minutes clock.
With the “SWISS” text being placed too close to the 30 minutes tick, you can see how the “MADE” text on the replica vs genuine Rolex Submariner is placed too far away from the tick.
Moving on to the genuine Rolex Submariner watch from the Rolex Submariner replica vs genuine image above, you can notice how all of the ticks and the words are placed correctly and perfectly, all of them at the same distance.
That aside, you can also notice several other minor differences in the way the characters on the replica watch are built: the “A” inscription on the genuine watch, for instance, is significantly different than the one found on the fake watch.
Step 2: Verify the date window on your watch
As for the second step of the guide on how to spot fake Rolex Submariner watches, we are going to check out the genuine vs replica Rolex Submariner watches for their date window.
https://imgur.com/xQqMWV0
In the replica vs genuine Rolex Submariner image above, we have pointed out how the replica Rolex Submariner watch has its number which indicates the date looking different than the one on the genuine Rolex Watch, due to the placement.
Looking at the authentic Rolex Submariner watch, you can notice how the number “1” is placed evenly, in the middle of the box, while the replica watch has its “1” placed higher than the one met on the genuine watch, leaving too much blank space at the bottom.
Let’s also have a look at another date number Rolex Submariner authentic vs replica image for your reference, in order to learn how to spot replica Rolex Submariner watches.
https://imgur.com/Vig1x9a
Once again, in the replica vs genuine Rolex Submariner image above, we have pointed out how the number “5” found on the genuine Submariner watch is perfectly centered in the middle of the box, while the replica “5” is not.
In fact, if you take a close look at the number “5” on the replica Rolex Submariner watch above, you can notice how the “5” is misplaced, as it is placed too close to the right edge of the box.
You can almost always expect perfection from a genuine Rolex Submariner watch, taking into consideration its price and the highly precise Swiss craftsmanship! The devils are in the details so replica manufacturers, on the other hand, will always have minor eye-visible flaws in their Rolex Submariner replica watch.
Step 3: Look at the bracelet (strap) design
Moving on to the third step of the guide on how to spot replica Rolex Submariner watches, you have to flip your Rolex over to the bracelet (strap) and check out the quality of the design and of the materials used.
You can notice the poorer quality of the materials used for the replica watch in the image right below.
https://imgur.com/GRi5OOX
Looking at the Rolex Submariner replica vs genuine image above, you can notice how the genuine Rolex Submariner watch’s strap material is made out of oyster steel, and how on the replica Rolex Submariner, the strap looks like it is made out of poorer quality material.
Also, keep in mind that the authentic Rolex Submariner watches are not bulletproof, but since they use oyster steel for the bracelet, it is really hard to scratch it, so a fake Rolex Submariner watch can be spotted out if it has a lot of easy scratches.
Step 4: Analyze the pearl of your Rolex Submariner
Up next, we are going to check out the genuine vs replica Rolex Submariner watches for the pearl on the dial, which is another small detail that is flawed by the replica Rolex manufacturers.
https://imgur.com/b8oodqA
In the replica vs authentic Rolex Submariner watch image above, we have pointed out how the replica Rolex watch has its pearl improperly fit into the “case” in which it stands.
Looking at the genuine Rolex Submariner watch, you can see how the pearl is placed correctly, as well as it has the same height as the “case” in which it stands. The material is also high quality and does not have any imperfections.
Going to the replica Rolex Submariner’s pearl, you can notice how it is placed too deep, as the metal material “case” is higher and bigger than the pearl.
Step 5: If possible, get inside the watch and check the inscriptions
Moving on to the fifth step of the guide on how to spot replica Rolex Submariner watches, we are going to check out the interior of the genuine vs replica Submariner Rolex watches.
For this step, you’ll have to open the Rolex Submariner watch, and so, if you have the possibility to do it, we recommend you do it since this is one of the most important spots to analyze if you can.
https://imgur.com/8wCRpwV
In the replica vs authentic Rolex Submariner image above, we have pointed out a critical fault met on the replica Rolex watch, which is the missing of the interior inscriptions.
Also, you can notice how the replica second-hand watch has poorer materials used because of the stains below the case on the bottom side of the watch.
On the authentic Rolex Submariner watch, you can see how there are no stains or flaws under the watch, as the quality of the materials is perfect and it does not have any comparison term to the replica Rolex Submariner.
Step 6: Examine the cyclops lens
For the sixth step on how to spot fake Rolex Submariner watches, we are going to check out the fake vs real Submariner Rolex watches for its cyclops.
By cyclops, we are talking about the crystal magnifier window above the number which indicates the current date set on your watch, visible in the image right below.
https://imgur.com/bJ8KaWy
Looking at the replica vs genuine Rolex Submariner image above, you can notice how the replica Submariner watches’ cyclops is improperly placed, as it is not centered in the middle of the box that displays the date number (date window).
On the other hand, the authentic Rolex Submariner watch has its cyclops placed correctly, as it is perfectly centered in the middle, above the date window.
Conclusion
Thank you for being with us until the bottom of the post. If you find anything wrong in this guide (and please do!), let us know in the comments, and we are going to fix it. As we previously said, our aim is only to help people differentiate the authentic watches from most of the replica ones.
As for our future plans, we are going to release more guides on how to authenticate watches and come back to share the information with you guys.
The link to the full guide on our website is: https://legitcheck.app/guides/watches/rolex/real-vs-fake-submariner/
Eventually, you can also read our guide on the iOS/Android mobile app (which is 100% free as well).
Please note: a Rolex Submariner is not automatically authentic if this detail is present. We expect some replica manufacturers are already picking up on this flaw. This specific step is only added so that you can instantly call a watch fake if this flaw is present, but not the other way around.
Looking at the authentic Rolex Submariner watches, you will always notice the Rolex inscriptions, never missing.Also, you can notice how the replica second-hand watch has poorer materials used because of the stains below the case on the bottom side of the watch.
Conclusion
