Hello,
(First of all sorry for my not very good English, I hope to be understandable.)
I'm here to get help putting back a spring bar of a Datejust Jubilee.
I had very few Rolex and by wanting to remove a part of the bracelet, it is impossible to put back the Spring Bar.
Here is the area in question :
I removed the bar, but I can't put it back.
Either it clips well at the bottom but not at the top, or the opposite.
I tried to put the srping bar alone, it's ok, no problem.
I tried with another bar, it works well but since the replacement bar is thinner than the original one, the clasp doesn't work well and doesn't close...
I wonder if the end of the original bar is a little broken or shortened...
- Do you know how I can put this bar back on ?
- Do you know where I can find an identical pump ? Especially with the same thickness so that the clasp can close properly.
Original Bar is here :
I'm annoyed because it's not even my watch.
Many thanks for help.
