How to build a Franken(?) sub without gen parts?
micksmith1987
625
237
Hi folks,
so it's becoming quite difficult to get gen parts. I've been thinking if one can build a pretty accurate replica using only ARF/Noob/VRF parts? I'm thinking of doing a 116610LN.
I think the best set will be like this:
1. Case - Noob V9 SA3135
2. Movement - Yuki 3135? Or arf sh3135?
3. Hands - ARF
4. Dial - VRF or BP?
5. Datewheel - Noob is good enough?
6. Bracelet - ARF
7. Clasp - ARF too? or is noob better?
8. Crystal - noob? (I know that prof is good, but what about stock crystals?)
9. Insert - VRF?
10. Bezel - Noob?
Let me know what you think!
Tobel
Put Some Respect On My Name
6/7/17
5,425
3,618
The very definition of a franken is that it includes gen parts ;) so you may call the above highly modded
One thing to consider, if you try to mix 3 or 4 different watches, you're likely gonna have to buy all of them as parts are usually not sold independently. So you may want to optimize and reduce the number of different watches
thrillofhunt
3,476
714
With all those money invested, its still a rep.
The whole idea of a franken is to add gen parts. If you add rep parts to a rep, its still a rep. Rep parts will never be as good as gen.
yakuuu
238
39
I think for a LN your best solution would be a Noob V9 with ARF bracelet, CF bezel, gen/prof crystal and maybe a gen DW.
This would be an arguably better watch than a possible mix of Noob/ARF/VRF and probably cheaper too.
bbit0
29/10/18
25
Sydney, Australia
Datewheel - Noob
Clasp - Noob
but how are you going to source all those rep parts?
I don't think TDs will source you individually...
