Fogging problem on dj41 ARF
Mustaf19
12/6/19
62
13
Hello, I received my datejust 41 rhodium this Saturday. Until today I had no problems. But today, fog appeared on the window. Like a thin film of grey on the glass. I didn't put it in the water. I just wore it on my wrist and just sweated from my wrist. Mist can't just appear with a little wrist sweating... Has anyone ever had the same problem? Do you have any solutions? I have contacted my TD (JTIME) to tell him, I am waiting for him to answer me. If someone finds a solution I'd be really happy!
processengr
2,928
13,554
Usually moisture condenses when moist air meets a cooler surface.
Try putting your watch in a sealed bag with desiccant or rice from unopened bag with the crown unscrewed and pulled out for a day to dry it out internally.
Mustaf19
12/6/19
62
13
Thank you for your answer. I put the watch on the dial side and unscrewed the crown. I'm waiting like this. I think I'll leave it as it is until tomorrow morning and if tomorrow the fog is still present then I try rice. What do you think of that?
processengr
2,928
13,554
This could help only if the humidity is low. The rice in a sealed bag will reduce the moisture inside the watch. When you screw the crown back in, it should be sealed from moisture.
Mustaf19
12/6/19
62
13
All right. I put it in a plastic bag filled with rice. I have more to wait and we'll see in a few hours...
Asmodeus
1,052
266
Rice can only bait chinese underpaid children to come over and fix it for you. If as you say you didn't get the watch wet and this happened, it will obviously happen again. Then you would have to pay someone to solve the potential issues caused to the watch. Also rice can include some powder created by friction, and you just don't want that stuff in your watch.
optical
848
77
This doesnt mean the watch has had water in it, I have had something like this happen to my watches that i know is water resistant. Here's how it goes.
You are in another country, that has high humidity (like a lot in asia for instance) and you open the crown, and set time, what ever, and that high humid air gets into the watch, and you seal it in with a screwdown crown.
Then you come back home, to a southern winter, and all that humid air in the watch meets colder temperatures, and starts to fog up due to the moisture in the air solidifying.
I left the crown open for a few days so it would get the drier air inside. Putting into a sealed ziplog bag with those moisture gel packs will help even more.
Foxxfire
FoX, the Patron
20/1/17
1,146
425
EU / CH
The OP wore his watch for a few days only. No travel between tropic and boreal climat so far. That change in air humidity shouldn't be the cause.
IMHO the fog is from his sweat. I suppose the case back seal is missing or not placed properly by the factory. I am afraid Asmodeus is right and this watch has to see a watch smith.
Mustaf19
12/6/19
62
13
Yes, I only wore it for a few days without travelling. However, yesterday it was very, very hot here. It's a heat wave. Could it be due to her? It was over 40 degrees.
Vvvlllooo
2,412
1,770
There’s a leak somewhere and you probably want to fix it. Have it pressure tested and fix the leak for the sake of your movement. It’s a rep, they may look great but they weren’t made to be water resistance.
Mustaf19
12/6/19
62
13
Yes, I think that's it. I'll try to find a store that will fix it here in France... it's a fake so the stores don't like to touch it here...
johnlogan
9,574
11,923
Open the caseback and let it air dry or use a hair dryer!
Vvvlllooo
2,412
1,770
You can get it tested at a qiosk that sells watches, you see them at malls all the time in the US. They could care less if it’s a rep and have it pressure tested for leaks. Once found you can contact a modder in your country, look for one in tech section, and have it fixed. It should not be too much. Grease gaskets seals or the crystal is usually the culprit.
Mustaf19
12/6/19
62
13
Yes, I'll wait until tomorrow and see if the fog goes away. And then I'd probably see a store in a mall for a test. Thank you all so much for your help, it's great to have a community like this.
