- 24/7/13
- 24
- 0
- 0
Hello everyone,
I just received an ARF 116610lv and looks great, but there's an issue with the date and wanted to ask you if that's normal.
When changing the time with the crown, the date changes perfectly but when the watch is functioning normally it may takes up to 8 hours to change completely.
The date changes perfectly With a snap within 5 minutes from 12 on only if I change the date with the crown, or if I use the crown to make the minutes hand go over 12. The date then changes perfectly with a snap and sits right in the middle.
The problem comes while using the watch normally, you expect the date to change near 12 with a minor movement and then a snap as when moving the minutes hand with the crown but, about 60% of the time, in some way it appears to not have the strength to do the change and moves slowly. After half an hour the date has not changed and after several hours the date still won't come completely straight but it's somewhat crooked.
This might be related to the issue: when changing the date with the crown, feels great from the 1st to the 25th approximately. From then (26-31), changing the date gives turning the crown a kinda rough feeling, and the date wheel doesn't snap (but does change).
Also, if the date is halfway changing and y pull the crown and advance just one minute the minutes hand, the date will immediately position correctly.
Is that acceptable? Normal? Might my local watchsmith be able to adjust it or I have to return it to the AD ASAP?
Pictures here
https://imgur.com/a/4X6U2h6
Thank you!
Pictures here
Thank you!
