I’m in the middle of a build using:
- gen 16014 case
- gen linen dial
- gen eta 2836-2
- raffles movement ring 2
- raffles dial spacer
- Tudor hands
Im following instructions on this thread: https://rwg.cc/topic/158976-diy-how-to-make-a-frankenjust/
Everything was going great and I actually managed to line DWO pretty well but alas when I put dial (with movement ring glued to it) and movement (with dial spacer clicked onto it) into the case, the stem height is about 1.5mm off, which means the stem can sort of go in but at a 20ish degree angle - hence could snap.
not what to do as the movement just seems to sit too high, not sure it’s a movement spacer issue. What can I do next?
- gen 16014 case
- gen linen dial
- gen eta 2836-2
- Tudor hands
