Daytona rotor - HELP
pascdumal
1,582
164
Hi , question :
- I changed the arf caseback with Noob caseback but the rotor is not ok ... does anyone know which rotor (maybe slim) should i buy on Ebay to replace it?
JDM180
1,212
244
you need to remove the deco plate and fit a regular rotor , you need the screw as well and either bend or double up on holder tabs
johnlogan
9,557
11,812
Thank you for a very informative post. If you change back to ARF caseback will the rotor be ok than?
pascdumal
1,582
164
Thank you !!!! Last question : any ebay link about rotor?????
