- 13/6/15
- 2,412
- 1,770
- 113
So, there is a lot of hype on the V9 Noob that just came out. There were also a lot of concerns with the SELs. This write up compares the V9 to a Gen, the new bezel construction, and clasps. I also had an ARF bracelet I had ordered and installed on the V9 to show you how it would look with it on. I will tell you that the stock V9 Noob bracelet felt so much better and solid between the two. Both are made from 904L steel. Although I feel both are made very well I may have to modify, a little, of the ARF to make it sit nice and right. I will post in the future once I this is done but at this time, right out of the box, the Noob sits perfectly as it was made for the watch. I think both options are very good if you happen to go this route and there is no wrong answer, you only feel it in the pocket book. Off to the Picts.....
V9 vs GEN
V9 vs GEN
