- 19/10/17
- 2
- 0
- 0
So I've decided on a Rolex Oyster Perpetual 39mm with Gray Dial. However, I'm having a little trouble with movements.
First of all I'd like to say I'm new (hi everyone) and I've done a fair bit of research into this but I still have a few questions.
So far I've found that the general consensus is that JF's Oyster Perpetual is a 1:1 super rep. However, I've also seen people say that the SH3132 movement is less than satisfactory. I'm not entirely certain of the general consensus on this though - some people have said it's utter garbage and the only reason you should consider it is if you're replacing the movement out of the box, others have said as long as you give it a service it will be very reliable, and some people are saying it's a decorated Yuki which is superior even to the ever-reliable A2836. So what is the general opinion on this? Specifically, this watch: "Oyster Perpetual 39mm 114300 JF 1:1 Best Edition Gray Dial on SS Bracelet SH3132" (can't post the link to the puretime page, account isn't old enough)
Secondly, how does the other gray oyster perpetual available on puretime compare? It's listed as "Oyster Perpetual 39 114300 1:1 Best Edition Gray Dial on SS Bracelet A2824", $288. I can't see a factory name in the title, just the A2824 movement. How is this movement generally viewed? Is it reliable like the A2436?
Any help would be great, thanks!
