This is a timegrapher pic, it's meant to show you how your movement is running :
Time keeping or deviation is how your watch is keeping the time, in your pic, your watch will gain approximately 7second per day
Amplitude is an indication of the running of your movement, you have a correct amplitude here
Beat error is within correct value too
Everything else isn't really a concern, but now that you have the term you can do some research on them if you wish to know more about them
Be aware that those are given for the watch in the current position, those data will vary during the day and how the watch is positionned, hence why on gen you see often the indication "adjusted in X positions" they try to achieve the better result possible in all the positions they regulate the watch for
